Hello,
I have installed an aluminum gas tank in a fiberglass boat. I'm uncertain on where to connect fuel fill ground wire that is screwed onto the metal fill. It is a perko fill (metal with a plastic ring).
Fuel sender on tank has a spade plug for ground from tank to fuel gauge ground terminal. Have that connected. Then from gauge ground to battery negative. Have that done.
Any advice? Thanks.
Any advice? Thanks.
