fuel fill hose blocked angler 204 fx
joe009
i have a 2008 angler 204 fx, and the fuel fill hose must be kinked under the floor.when i try to add gas,i can only pump 2/10 of a gal before the hose backs up, shutting off the pump. i tried to snake the fuel hose and stops 1/2 way from the side wall and the fuel tank.i am trying not to lift the floor. any help will be appreciated
Grub54891
A bit of a reach, but it's possible the hose is to long, causing it to kink someplace. Disconnect it at the filler neck and see if you can get some slack out of it, cut off the extra hose. There should be a deckplate in the fuel guadge filler area also, remove that and have a look from that end. If no plate, You could add one.
ken51k
It might not be the fill hose, check your fuel vent to make sure it isn't plugged up. If the vent is plugged it will act the same way.
Grub54891
Yeah,I was going to mention the vent also, but got distracted......
joe009
thank you for the replies.i blew out vent hose and there didnt seem to have any blockage
