Les MacDougall
- Joined
- Nov 25, 2008
- 26
2000 Yamaha 250H.P. OX66 Saltwater Seris.
Engine cuts out when running hard or up and down a wave.
Should the Clear Fuel bowl on the side of the Engine be full of gas?
There is about 1" of air that remains at the top of the filter,even when running.
It seems the Fuel is barely high enough to penetrate the Filter media.
History:
The Filter is new.
The Screen in the VST is clean.
The Hi Press Fuel is new.
The (3) Low press Fuel pumps are new.
The Bulb in the Gas line is new.
The gas Fill-up caps were removed, No suction problem there.
The bulb and short piece of Fuel line was put in a Portable Gas Tank.
It seems to be Fuel related.
The Engine will run longer (full Throttle) when the Bulb is pumped.
Thanks,
Les
History:
The Filter is new.
Thanks,
Les
