Fuel Filter / Seperator Question. Bulb is Collapsed
BajabossJD
Hey guys... I took the boat out last weekend and all was running well.. At then end of the day, boat acted funny and died. I got towed in and was thinking I has a fuel problem. The boat wouldnt resart.
Today, I tried to start the boat and it fired right up. I had it on the hose and noticed the bulb was collapsed.
On this Merc 454, I have a Parker fuel / water seperator (with bowl) mounted on the back of the bench seat in the engine bay. This gets its fuel from the tank.. on the output side of the filter, I have the primer bulb which is flattened. From there, the hose goes to the engine mounted Sierra fuel filter.
Do I need to have two filters? Can I just bypass the Parker unit and have the fuel line go directly to the Sierra spin on? I am thinking I have a blockage in the parker somewhere (the bowl is full).
I opened up the gas fill cap to see if it relieved pressure on the bulb.. It didn't.
Thanks,
Joe
Re: Fuel Filter / Seperator Question. Bulb is Collapsed
Ayuh,... It could be the parker filter, or the primer bulb,...
Ya don't need either...
Or it could be a problem Up-stream at the tank...
All ya need is a canister filter, before the fuelpump, 'n then the carb...
Don S
I/O's should never have a primer bulb installed in the fuel system.
BajabossJD
Thanks for the info. This seperator has a plastic bowl in it too.. Seems to be wrong for the I/O.. Dangerous.
I will scrap the Parker and just get a new filter to mount the engine and connect the fuel lines to bypass the Parker. If that works, I will scrap the bulb and get a new line.
I will also take a look at the tank connections under the Pie in the floor. Maybe the anti siphon valve is stuck?
Thanks,
Joe
