fuel filter/water separator
flashback
spin on fuel filter for a mercruiser 350 chebby 1980 model. dumb question.. the filter says it is also a water separator..where does the water go after it is separated.???? :confused:
Chris1956
Re: fuel filter/water separator
Flash, That device feeds gasoline to the engine from the top of the canister. The water sinks to the bottom of the canister. That is how it "seperates" the water from the fuel. If the canister fills up with water, the water will then go to the motor.
flashback
Oh man, thats just wonderful... I guess it's better than nothin tho.....Ive seen those recor filters that have a plastic bottom on them with a drain plug..that makes more sense to me..thanks
lakelivin
Any way to tell when the seperator needs to be replaced (i.e., how much water is in it)?
crazy charlie
Yes there is a way to tell.The motor will surge,sputter and the die.Thats how you tell when it is full.I rather replace it every spring as pre.maintenance.I did the sputter and die thing once and learned my lesson.Charlie
trog100
less than the 16oz bondo just told u to pour down the carb.. he he he..<br /><br />strikes me as one of those devices that might cause more problems than it cures.. stores up all that nice water then feeds it neat to your carb when u forget to change it.. he he<br /><br />trog100
tommays
they dont seam to be rated for in enclosed motor unless they have a metal bottom but you can still drain then<br /><br /> http://www.maesco.com/products/racor/r_gas/r_gas.html <br /><br /><br />tommays
flashback
Trog I luv you... It is one of the things that work some of the time but not all of the time,,,,and when the bottom rust out. you have no worries .........................BOOM
flashback
by the way, I don't see anything from bondo,,trog
Ayuh,.................<br /><br />I've Always Thought that trog was Cross-Threaded,... Now I Know For Sure................................... :D
KaGee
Originally posted by Bondo:<br /> Ayuh,.................<br /><br />I've Always Thought that trog was Cross-Threaded,... Now I Know For Sure................................... :D
Cross threaded? Heck no....he's flat out twisted off! <br /><br />Now where's the easy out???? :D <br /><br />Trog.... we luv ya man!
