chrismarion
- Joined
- Apr 12, 2006
- 115
I am getting closer to going insane while fighting this fuel/water separator. Its not a pump problem since the system works perfect if I bypass the separator. I can pump that primer bulb as much as I want but it aint doing anything. I can look at the clear glass filter and see that the fuel is not flowing. I put on a new filter to see if it was clogged, that was a waste of $8. Check the lines and the fittings at the filter, clear.Took off the filter to check the port holes and they are clear. Screw filter back on and restart the war. I cannot get this thing to prime for my life. Yes the filter is full of gas, I can suck the gas out of the filter for a bit and then it stops.
System primer (parts in West Marine Catalog):
under deck 16 gallon tank (Tempo#640030), 90 degree elbow at top of tank and runs though 3/8 line parrallel to the top of the tank to transom. There it goes into a glass filter(Tempo#170025), then up 7 inches into the fuel/water separator (Sierra# 18-7852-1)and out to the engine which is above it. WHY wont this thing prime? I have tried different configurations of the lines going into the filter, but with no luck. The filter isnt leaking and I dont hear air sucking in at any of the fittings.
If I take the separator out of the equation, all is well. Put it back in and it starts over again. Can I or Should I put in a small 2psi electric pump before the separator? I really would like to have that extra insurance of having it, but not if I cant use the boat.
