Re: Fuel filter
They should be nearly full, if it has a big air pocket in it and you are able to move the filter turn it carb side up and pump the bulb to push the air out. If it is fixed to the power head I would not worry about it unless you are having running problems, then you might have a air leak in the line between the filter and the tank.
