Fuel Gauge Help!
KJ
I need help determining what is going wrong with the fuel gauge on my boat. With the system off, the gauge goes down to below E and when running it stays pegged above F. Once in a while I will see it bounce down from F to what I think the level actually is, but it is not the same each "bounce". It will go from F to 3/4 to nearly 1/2 and then back to F and stay there for some time.
Any ideas would be great!
studlymandingo
Re: Fuel Gauge Help!
Most likely it is a shorted wire. Take the leads loose from the sending unit then turn on the key. If no change it is either wiring or the fault of the gauge. At that point, you can remove the "s" wire from the gauge, if no change still, replace the gauge, if it drops to "e" time to run new wires.
Solittle
It could also be the sending unit itsef - a common problem and easy to replace.
KJ
Thanks for your help, I will give this a try.
Texasmark
Don't know your electronic moxy.
Battery voltage goes thru ignition ON switch to fuel gauge system.
Gauge and sending unit are in series with battery voltage. Sending unit resistance changes from a small resistance (35 ohms roughly) to a large resistance ( 265 ohms for a number; probably pretty close for a guess). One of those numbers is supposed to record E on the Fuel gauge and the other F; don't remember which.....doesn't matter.
With the fuel tank float bouncing up and down all the time it wears through the "sending" part of the system and the circuit opens up....just like the fuel system sending unit does on your truck if you live on a piece of .......rual road like I do....BTDT
Once the circuit is open, the gauge either pegs F or E; don't remeber which and it doesn't matter; it's one or the other.
Hopefully you get the idea.
Mark
puddle jumper
My boat had the same problem i found that the plug on the back of the fuil gauge was loose .An easy way to test this is to un plug your fuil sending unit and it will read eather full or emty.If it reads emty tuch the two wires together and it should read over full.Then with the gage reading over full wiggle the wires all the way up to the gage and if it does not move the problem is probably
the sending unit is worn out.
Tail_Gunner
This can be a very simple solution, just take a $10.00 ohm meter and measure the resistance you sending unit display's.
That is pull it out of your tank, hook a ohm meter, move the flotation device up and down, if the ohm meter varies widly you have a bad sending unit.
They are a very inexpensive device and usually they are the culprit, before you go to any great lenghts be sure of the integerity of your sending unit............8)
DUKE1
Here's another idea. I got tired of replacing the sending units so I went with manual gauges. Granted I can't get the reading on my dash, but I just pop my round access hatch over each tank and I have the gauge to read. For me anyway...two less things to break or be replaced any time soon (I hope). You just need to know the depth of your tank then you can get the manual gauge. They are cheaper too. For clarification the manual fits into your tank the same as the electric unit.
Duke1
ricksrster
My boat did the same. What was happening was that the send wire connector on the back of the gauge was grounding out making the gauge always read full when the key was on. With the key off, the gauge should go to just below empty.
KJ
Thanks everyone for your help! Looks like it was definitely the sending unit.
