Fuel Gauge Hook up
I just re-powered my boat with 2- DP300AP Suzuki engines (2016). The dealer who installed the engines could not figure out how to hook up the existing fuel senders (they are Centroid Electronic sending units). I noticed that the Neama Cable has 4 wires blue, red, white, black. The sending unit has 3 wires (red power going to the sending unit, black ground, pink for signal). Does anyone know what the color codes for the Neama cables are? What hooks to what?
welcome aboard.
the NMEA 2000 network is a variation of CAN. your standard 3-wire fuel tank sender is simply a dumb resistor. you need a NMEA compliant fuel sender or one of the converters such as Simrad EP 65R or Lowrance 65R
