I need some advice from some of you that may have more knowledge than I do when it comes to fuel sending unit/gauge. I recently removed my 62 gallon fuel tank for draining and cleaning. I replaced the float sending unit with a new one that looked exactly like the one I took out, but discovered this week end that it is not reading correctly.
First let me say I have not filled the tank with fuel, only 60.00 to 80.00 dollars worth at a time and the gauge showed about 1/2 full, which I expected was about right, but then ran out of gas with the gauge showing 1/4 tank left. I know on install I ajusted the float all the way to the end of the arm as per the directions on the package, for the deapth of the tank I have. Now the tank is empty and the gauge is stuck at 1/4. Any ideas?
thanks
pbgeneral
thanks
pbgeneral
