Re: fuel gauge not working
I use a 12v test light to test those. They have a wire with an alligator clip on the end for ground and a screwdriver-like body with a light inside and a pointy end like an ice pick. Less than $10 most any place that sells sparkplugs.
Put the alligator clip on the negative post on the gauge.
With the key on, touch the probe to the positive post. If it lights, you have power to the gauge.
Touch the probe to the sender post and the needle should just about peg to full. If it does, the gauge is good.
Then go back to the sender and put the alligator clip on the ground lead there.
Touch the probe to the center post and the gauge needle should just about peg again. If it does and the gauge reads empty but you have gas in the tank, replace the sending unit. Make sure you disconnect the battery before you do, and avoid any static sparks.
