boat4fun83
- Joined
- Oct 19, 2008
- 45
My fuel gauge is not working. I have checked the gauge itself and it works when you ground it. The gauge always reads full and every once in the while when you tap on the gauge it will move but always goes back to full. When engine is off the needle goes all the way down. I have pulled out the sending unit and it read the correct ohms when in the up and down position. I cleaned off the ground connection. I'm not sure what to check next other than the wiring which I would have no clue how to do because those wires are bundled with all the other wires.
Any suggestions? I have thought about pulling the sending unit out and hooking it up to see if it works. Is this okay to do or will it mess something up. Currently it has too much gas to pull the unit out so I have to check it next weekend while out.
