NW Redneck
- Joined
- Jul 30, 2006
- 643
Should have known after a great trip with no problems something would have to go wrong......
Everything working perfectly yesterday. Today went & tidied up the boat for the next outing. Turned on battery switch & key to first position (switched power on) and my fuel gauge didn't move. (I know there's between 1/3 to 1/2 tank) All other gauges/lights sprang to life like normal. Checked all connections on back of gauge and at sending unit on tank and all are tight & clean. I had cleaned and applied electrical grease on everything last year. I disconnected all the wires from the back of the gauge except the lead to the sending unit and attached jumpers from ignition 12v to 'S' (switched power-purple wire) on fuel gauge and from gauge to good ground. I'm reading 12.16v from ground to 'S' and 7.92v from ground to 'L' (sending unit terminal). I also get 7.92v from ground to the sending unit lead connection at the tank. I'm thinking the gauge is shot and was wondering if there is any other way to test it or have I prety much covered it?
Thanks in advance!
Thanks in advance!
