Re: Fuel gauge problems
Hey Magicbandit,<br /><br />This will either help you out, or make you laugh!<br /><br />I had the same problem as you seemed no matter how full i filled her up it would read a max of half a tank, needle straight up 'n down.<br /><br />Grounded the gauge, and the needle went past the full mark, so i presumed it was the sender.<br /><br />Pulled out the sender, it looked ok but i pulled it to bits and cleaned it anyway, after cleaning i hooked it up outside of the tank and manualy moved the float arm on the sender - the gauge still only read half a tank at most.<br /><br />Pissed off by now i pulled the gauge out of the dash and pulled it apart, dont do that! couldnt see anything of note inside the gauge, so now really pissed off i started to put it all back together.<br /><br />Heres the kicker, as i put the gauge back in the dash i noticed the needle moved - without power.<br /><br />A bit of thinking later and i realised my problems with the gauge started about the same time i installed an extension speaker for my VHF, i mounted this speaker directly under the fuel gauge.<br /><br />It appears that the magnetic force of the speaker was to much for the gauge to overcome, hence the needle tried to stay dirctly straight up and down as much as possible.<br /><br />Moved the speaker, kicked myself in the pants, and now all is good
<br /><br />Sorry, just a long winded way of saying, look simple before getting stuck in, may save you time<br /><br />boatin happy,<br /><br />W'fish
