swick
- Joined
- Aug 15, 2009
- 282
Hi guys, got a new scenario to figure out on my 99 120hp Force outboard. Haven't used it since the summer so I took the carbs off, cleaned, and reinstalled. Not sure if this is the cause or part of the problem, but lets debate it a bit. The new thing is that I can't start the engine without pouring a little fuel into the cylinders. That being said, when I do, it fires right up, no problems and continues running fine, after which it will fire up fine without need to pour more fuel into the cylinders (as long as I let it warm up the 1st time around). I installed a fuel/ water separator, thinking maybe the fuel itself was questionable, cleaned the fuel filter out, and replaced the primer bulb and fuel lines. This eliminates a lot of other fuel scenarios, but still can't figure out why the need to pour into the cylinders to get it going initially. Any thoughts?
