Fuel in oil?
rabbyg
Hi Folks, We have discovered fuel in the oil, rather alot of it, the smell is very strong.
does anyone know why this is?
We have an 88 bayliner 2.3 omc.
this is the vid from the 1st start up. anyone know why its smoking/steaming so bad?
http://youtu.be/ORvkZNy_hXM
tpenfield
Re: Fuel in oil?
I'd say that there is also oil in the fuel, and maybe water. I'm thinking a cracked cylinder block. How far are you from the North Sea?
etracer68
Ensign
Re: Fuel in oil?
First, are you running on muffs? Could'nt see with all the steam. Fuel in the oil, generaly indicates, a float not seating in the carb, letting to much fuel in the motor while ideling, and it gets past the rings, and into oil. Look into the carb while ideling, and see if it is dripping fuel fast down inside the carb.
HCMQA
Re: Fuel in oil?
You are running that without water?!?!?!?!
That could be burning rubber smoke.
