motor stumbles while rpm coming up (under load) ... (around 1500rpm) sometimes. compression 150 lbs on all cylinders except one 121 lbs. 118 hours on motor. any ideas ?
larry - The moderators will most likely move this to the Johnson problem section. This section is not for engine problems. Oh and when it stumbles squeeze the primer bulb & see if it picks up.
