fuel injectors
Cool It
hello- I solved the problem with the oil level there are no more alarms going off and pressure is perfect -thanks for the help-now I seem to be having a new problem- sometimes when I go to start the boat it seems to not be getting gas it stalls -then Ill do it it a few times and its starts -or somestimes I will not get anything when I turn the key a couple of times then It will start no problem on another try- once Im running It runs fine- can this be a fuel injector problem - when a fuel injector is bad does it just go or do you see symptoms first - can they just be dirty? oh Im sorry my engine is a 2000 5.7 merccruiser EFI with a bravo 2 outdrive-thanks cool it
