Re: fuel inlet hose on Tahoe Q6
If it is the fuel vent hose that is loose at the tank it should be easily fixed by just putting back on the tank. It will go on the tank next to the 2 in. hose. If this the vent hose gas would be leaking in the motor well. Knowing the boat and you have no gas leak or fume problem in the motor well
I believe the hose you are talking about is the drain hose from the tank below the aft port, right side faceing the motor , raise the small cushion , pour water in this tank to see if water goes into the motor well , maybe even the center floor locker. If so with this hose loose the boat can sink. This hose hook to this tank in the same ares as the fuel hose ,could be confused by a newbe.Reach in motor well behind this tank there is some grey foam , pull the foam loose where you can see the fitting on this tank ,you should be able to loosen the clamp enough to slide the hose back on and tighten clamp back. Add some type of sealer to the hose when put back on.
