Fuel Issue for a 1978 merc 470
bently
This is not really a tread about my 470 but my fuel supply line no longer supplies fuel to the fuel pump. the pick-up hose either disconnected or became brittle and broke. I can pressurize my fuel tank and air will leave through both the vent and fuel supply line. My tank is in the floor which I just completely replaced last year and decided not to recreate the removable piece above the gas tank.........Now I get to cut up my nice, no seems, floor to replace a $1.99 fuel hose.........
sucks.
jabfd
Re: Fuel Issue for a 1978 merc 470
You should no more or less where the connection on the tank if you just replaced floo
I would use a hole saw to drill the floor In that area then you will see where the fittings. Cut the hole with a jig saw and add a access cover they sell them in many sizes good luck
bently
I was able to cut open an access to where the out going fuel line is on the tank.
how does the silver square fitting come out of the tank? Does it just screw out?
Thanks
bently
Here is a photo of the fitting.
Bt Doctur
Are positive you have enough fuel in the tank for the pickup tube to pick it up? its not a hose ,its a tube that goes to the bottom of the tank. usually unscrews from the tank fitting. Tanks are designed to NOT suck up every last drop. could have as much as 10-15 gallons of what is called "unuseable fuel"
bently
I was able to drain it almost completely last fall. I put 5 gallons in this spring and the boat is sitting in the same spot so it is in the same level position but now I am just getting air out of the tank. That is why it seems wrong/different. So that fitting will just screw out so I can atleast check it?
Thanks
MikDee
Banned
Yes! and that might be your anti-siphon valve.
