Adding more information. Ok I changed out everything but the fuel pump and everything seemed to be working fine. Except I had to take out the anti-sphion valve because my local marine place was out of stock on them, so I just replaced it with a normal brass barbed fitting. Drove the boat last Saturday all day and the fuel filter would stay full when driving.
The only disadvantage was if the boat would sit for an hr or so it would drain the fuel back to the tank. I replaced the anti-siphon valve on Tuesday and went back out yesterday for the 4th and started having the same issue. After idling for long periods of time the fuel filter would go empty causing a bad bog when trying to go faster then idle. I also noticed after cruising at 3krpm it wouldn’t fill the filter up either.
I'm starting to thing my fuel pump doesn’t have enough suction to pull past the anti-siphon valve. Is this possible?
I stuffed a Mercruiser 140 (3.0l) in a pontoon. Everything worked great my first time out except up at speeds water got pushed thru the vent and into the tank.
Drained the tank and continued on. Ever since then I have been having this issue when Idle for a long period of time my fuel filter will go empty. If I run the boat at 1500rpm this isn’t an issue. If I take the primer bulb and squeeze it, it will fill right back up. I'm thinking fuel pump doesn’t have enough pressure at idle but then again it shouldn’t take much at idle to keep up.
I know its not venting as I can leave the gas cap off and it does the same thing.
Thoughts.
I attached a few picture of the engine area so you can get an idea.
Thanks again
Mike
Thoughts.
Thanks again
Mike
