fuel issues JS 130hp ocean pro Year2000
seahunter585
Hi all I have a 130hp ocean pro built 2000 the fuel bottle bulb that runs off the water seperator fillter is not filling up I need to keep hand pumping the bulb to keep the motor running is the VRO the problem or air any need help.
boobie
Re: fuel issues JS 130hp ocean pro Year2000
Sounds like a bad air leak or a vro that is not pumping fuel.
seahunter585
hi again thx 4 the imput. it is cold over here so the hoses cold have a bad seal. I did remove the water seperator and may have not tightened it very tight ill cheak in the morning. cheers
boobie
Let us know what you find.
seahunter585
I did get a little more from it but carnt check it till the tomorrow i left the hose on the ear muff and my daughter broke the hose conector. cheers. I might get some new fuel hose while i am out.thx
