fuel leaking on switchbox
jason1150
72 mercury 1150
everytime I put my motor forward for trailering fuel leaks onto the switchbox out of the top carb, is this normal, seems like there should be a cover to protect the switchbox, thanks, Jason
Plainsman
Re: fuel leaking on switchbox
When I had that problem it was due to worn needles and or seats in the carbs. I took all the carbs off, replaced the needles and seats and it hasn't happened since. There might be a real small amount of fuel that didn't get burned off when it's shut down, but not enough to soak the switchbox.
Laddies
Banned
Yes, just think of the carb bowl as a glass of water as it's tipped it has to spill it's always best to disconnect the fuel line and run the fuel level down.
jason1150
thanks Laddies, can't wait to take the boat out and see how she runs, got the tach hooked up so I can get a better idea what's really going on, Jason
