I have an 89' OMC 140 (looper) with the plastic carbs (bodies and bowls). I rebuilt the carbs and replaced 3 out of 4 of the bowls because they were warped and leaking and have replaced 1 of the carb bodies for the same reason (new bowl didn't fix it). I finally have the carbs to the point that I can pump the primer and the bowl gaskets do not leak. However, after I had pumped the primer bulb checking for leaks, I tilted my engine all the way up and two of the carbs started pouring out fuel.
So the question - is this still the warped carb problem, could it be something else (valve/seat issue), or is this normal?
