Fuel line Alert!
john from md
Last season I needed a new primer bulb so I bought the Moeller bulb and hose combo. This is grey colored hose in a plastic see through package.
I do not remember if it said alcohol compatible but I CAN STATE WITHOUT RESERVATION IT IS NOT. :mad: Seeing that it was grey in color, I may have been misled that it was the same as SAE J1527 hose. I know now that it is not as it has softened and kinks everytime it has the least bend in it.
This weekend I had a hard time starting and the engine was backfiring. :confused: The tank was full and the bulb was firm so I was kind of stumped. I switched tanks and it started with no problem. I had filled the tanks within a couple of days of each other yet I thought maybe it was bad gas. :eek: The engine had run fine on muffs when taking it out of winter storage.
Now that I found the kinking hose, I believe when I switched tanks, it unkinked the line and fixed the problem. Today, after the rain stopped I got a chance to look around and found the soft line. :mad:
Just wanted to pass this on. I too became a victim of the gasahol plot to keep boaters off the water . ;)
And Maryland wants to up the percentage to 15%!!! Arrraagggh! :rolleyes:
John
