Fuel Line Coupling, 95? 70 hp
atengnr
Hi, all recently got this 70hp, possibly a 70hp, and getting some issues squared away. Is this the correct fuel tank line coupling at the motor? If not, what fittings belong here, and at the fuel tank line coupling? Also what about at the tank? Thanks, an OMC guy here, so not familiar.
Nordin
That is not the factory fuel fitting.
Larger Chrysler/Force have the fuel hose connect at the fuel pump with a clamp.
The connector is at the tank if it has a portable.
The fitting at the pics are home made and for nthe fuel I assume.
Tracy the hose and see if it is connected to the fuel pump which is at the starside of the engine.
