I installed new fuel line all the way to the motor (outboard) with new primer bulb. It primed (took a bit) and the motor ran fine but after sitting for an hour, I pumped the bulb again and it was dry. The tank is in the hull so is the lowest part of the fuel system and I am pretty sure the fuel in the line is draining back to the tank somehow. The primer bulb pumps up hard so I know the floats are shutting off OK and I do not have any leaks. Do they install check valves in the fuel line to prevent this or do I have another problem?
