JSGOLD
- Joined
- Sep 22, 2009
- 609
I just rebuilt the (2) carbs on my 1976 Evinrude 55HP motor and am getting ready to install. I want to replace the hoses from the fuel pump to the carbs and the small line between the carbs so I have all new system. The old line between the carbs was clear plastic and the hose from the pump to the carbs was a cut piece off a primer hose assembly. My question is....does fuel line hose for outboards HAVE to be special or can you use a good automotive type of line. Does the small line between the carbs HAVE to clear plastic? Plenty of automotive hise to be found but darn little marine hose to be found.
