Fuel Line Prime
Brew
How long after pumping the fuel bulb to "prime" the fuel line, should it stay primed (ie. gas in the line)?<br /><br />After priming my fuel line and leaving it overnight, the fuel line is totally empty of fuel. I figure it must be draining back into the tank as I don't seem to have a fuel leak. Would this be indicative of a bad fuel line bulb or an air leak somewhere in the fuel system? <br /><br />I seem to recall on previous boats I've owned that the fuel line bulb may go a little soft over a day or two, but not totally empty.<br /><br />Thanks,<br /><br />Brew
blueboat1
Re: Fuel Line Prime
Mine stays like that until i release it, I know at least 3 days
Brew
Re: Fuel Line Prime
Which is the more likely cause: Bad Bulb or Air Leak?? Both??<br /><br />Thanks
Cricket Too
Re: Fuel Line Prime
I don't think you have anything to worry about, primer bulbs, at least in my experience, always go soft again after 24hrs. or so. I usually prime mine up every time I go out even if I just went out the day before. They are only used to prime up the carb bowls before starting. I don't think you have any kind of leak. Good Luck.
