you should have 3/8" metal lines from the water separating filter to the fuel pump. and the same 3/8" metal fuel line from the fuel pump to the carb
the filter in the carb will depend on which carb you have, holley or quadrajet. available at any automotive store, however your primary fuel filter should be the fuel/water separator filter between your fuel tank and the fuel pump.
between the fuel tank and the fuel filter should be USCG A2 hose
NO, bad bad advice
no plastic filters allowed in an I/O fuel system period - outboards yes, I/O's no. if an outboard leaks fuel and blows up, the boat survives. if an I/O leaks fuel into the bilge and blows up, it takes divers weeks with small nets to find all the bits.
https://www.uscgboating.org/regulati...UELSYSTEM1.pdf
