zzimmer3
- Joined
- Sep 30, 2012
- 35
on my 1989 mariner 75hp, the fitting that connects to the motor requires a 5/16" hose, the built in tank and current fuel line with in line primer bulb is 1/4", is there a problem installing an adapter after the bulb? will it cause any fuel shortage problems? or should i change the fitting at the tank and all the lines and primer bulb to 5/16" line? thank you for your help.
