Fuel line sizing
belairbrian
I think I know the answer but figured I'd ask any way to be sure.
I finally got the hard gray attwood line off the new to me pontoon. The hose bulb and engine end fitting were 5/16.
The fitting at the pontoon gas tank is 3/8. That kind of makes since since the boat is rated up to 75 hp.
But with a 50 on it 5/16 would be the norm. Somehow the PO or his mechanic managed to force 5/16 over a 3/8 fitting.
Anyway, I was going to just get all 3/8 line, bulb and fittings. Can't see any harm in using bigger line.
But if someone knows of a reason not to use 3/8 on a 50 hp let me know.
It's a 1999 Johnson 50hp.
ondarvr
Re: Fuel line sizing
Just use the bigger stuff, there is no down side other than cost.
gm280
Use the largest size that will actual tighten up on the fuel inlet fittings and NOT leak. But seriously, even 1/4" fuel line would run your 50HP engine all day long at WOT without any fuel starving... So any size you want and will fit is okay... :cool:
