Fuel line type
Skegemog1
should the fuel line from
the connector to the fuel pump be type A1 or doesn’t it matter? This is on. 15 hp 2 stroke Johnson. Thanks
kbait
I believe factory used standard B1 fuel line 5/16” connector to pump, 5/32” pump to carb. Nothing wrong with using A1..but likely overkill for these outboards.. And if A1 has a wider OD, it may be challenging to install.
F_R
B1 is all you need.
