Fuel line
Status
Not open for further replies.
Pdevito
Has anyone upgraded to trident barrier a1 . If so any input
Trident makes good stuff and meets all USCG requirements. Have used it for fuel and raw water suction line. As with all this line, it's stiff and doesn't bend easy
airshot
I bought A1-15 rated fuel line from my local marine parts store, different brand name but same rating. Just under 8 bucks a foot..
dingbat
Big fan of Trident. Replaced all my fuel lines from separator to primer bulb to fuel pump with Trident A1 last week.
Bear in mind that A1 is designed for use in an enclosed area. It has a thick, fireproof cover and comes in a couple of different configurations ( bend radius). Check to make sure the bend radius matches your needs.
Hose type B1 is not fireproof and only approved for use above deck in open air. Typically used between the primer bulb and fuel pump. The infamous “grey” hose is is rated for B1 applications
SailorDreamer
I recently upgraded to the Trident Barrier A1, and it’s been a game-changer. The enhanced durability and weather resistance are noticeable, especially during heavy rains. Installation was straightforward, and it fits perfectly with my existing setup. Highly recommend it for anyone looking to boost their barrier performance. Anyone else have experience with it?
Status
