fuel lines for 85 bayliner with 85 force 125
fmf
Hello, need some help locating a new fuel line package for my set up. I am trying to replace the fuel lines from the tank to the engine, and cant seem to find the right combination of hose and fittings. anyone have a suggestion? local boatersworld was other than helpful, they probably have the pieces but the kid who helped me had less of a clue than me. thank you in advance.
fmf
Re: fuel lines for 85 bayliner with 85 force 125
sorry, its an 85 bayliner with 85 force 125
roscoe
A mercury deal will have them for sure.<br />Or get a generic hose/bulb, and buy the fittings, or use your old fittings.
roscoe
Or convert the entire hos system to a more modern and easier to use type.
ljshein
fmf,<br /><br />I have a similar boat, just a year older. I went to wal-mart and bought a fuel line kit with a bulb and all the hoses. It works very well. The line it the kit is long enough to reach fromt he tank all the way up to the motor, it's just a standard hose clamp on either end.<br /><br />Jeff
fmf
Thanks for all the replies. I had never thought of WalMart, I will check it out. Thanks again.
jastacey
When getting fuel hose, make sure it is USCG rated, some of those inexpensive kits have small dia. tubing, get the largest one you can find
