I was reading in my manual and it said during the break in period to use a 25:1 fuel/oil ratio. After the break in period (which is typically how long?) it said to use the standard 50:1. My question is this: My motor (73 Merc 850) has been sitting for 10 plus years. Should I consider using the 25:1 ratio to sort of "re-break" it in/re-lube the internal parts or just go with the standard 50:1? If using the 25:1 ratio isn't a bad idea, how long should I run the motor with that fuel mix?
