charliegiggles
- Joined
- Oct 19, 2006
- 50
Hi Again,
I have a 79 70HP mercury outboard. I rebuilt the carbs, put new floats etc. I set the fuel mixture needles "long silver needles on the front of the carb" counterclockwise one turn from lightly seated as per the instructions in the manual.
I'm having troubles starting the motor. I got it started but am certainly not following a "best way" to start it. The gear shifter is in neutral and I set the second smaller lever "starting throttle" to about 1/3 of the way. I then am cranking the motor and holding down the "choke" button while turning the ignition switch. The "starting throttle level" is properly adjusted and will close the throttle lever on the motor completely.
After several attempts the motor will finally start however I'm not sure if I'm suppose to keep the choke button "on top of ignition switch" pushed in continuously until it starts or use some other method.
Any help would be appreciated on the fuel needle setting and proper starting procedure.
Thanks as always...
Thanks as always...
