i have an 85hp force and have been having fuel probs(wont throttle up post), i took the carbs apart and checked them for the third time, i replaced the inline fuel filter and the fuel pump diaphragm. the new inline filter is a clear glass one and its fine at idle and even a bit of throttle however it empties out when i give it to much throttle so, the question is:is there something in the fuel pump besides the diaphragm that i should check? i also took the cap off the gas tank to make sure wasnt a vapor lock thing in the tank and made no diff. i have a motorcycle that had a prob with the glass in line filters getting vapor locked in it could that be an issue here? also could the primer bulb have a check valve prob?
