Re: Fuel Octane Rating?
My respose to higher octane fuels. I worked for a boat rental place for many years, during that time I've tore down and overhauled a lot of engines. At first this place used the lower grades of fuel, the engines when disembled had lots of carbon build up and some of the damage could be attributed to that. Then the marina started using only 93 octane fuel and any engines that I tore down had much less carbon build up. Now I'm not an engineer, or a scientist, but something caused this change. Under normal use I think that I would use a cheaper fuel. However rental engines only have 2 speeds, stop and all ahead full in this situation I think that the higher octane fuels are best.<br />Octane tends to slow down the burn, giving a smoother and more complete burn rather than an ex plosion. Higher octane fuels along with retarding the timing will produce more h.p. and usually better fuel milage. This can cause dramatic differances in turboed engines.<br />In WWII the big bomers were having a difficult time getting airborn with a full load of bombs, so they water injected them to slow the burn and increase the h.p. So I think that increased octane does help depending on what you want, and what you are using it on.
