I have just purchased a 2 stroke, 3 cylinder, 60hp Mariner serial number 9537575, it is approx 1989 and is oil injected. I will be premixing rather than using the oil injection as I dont wish to risk any problems with the oil possibly not being injected. The previous owner stated that the mixture ratio he used was 25:1, could anyone confirm that this is the correct mixture as running with water muffs the engine is pretty smokey, could the mixture have this affect? Should I be using the oil injection instead - would it have an alarm if there was a problem? You may have gathered I dont know a great deal about boat engines so help would be appreciated.<br /><br />Many thanks
