The fuel pump died on my 1986 Evinrude 40 hp with VRO. The OMC kit I used to replace it had been opened and the parts bag was missing. The dealer supplied what he said were the correct parts to make the installation on my motor. Those parts were different from what I removed and I have a question or two.<br />Caps are from the OMC label, I'm not intending to shout.<br />KIT AY, F PUMP&LMTR<br />P/N 438406<br /><br />The pump seemed quite similar and fit where the old one was with no problem. My old pump was the 3 wire pump and the new pump was the four wire pump and the harness and instructions for wiring were supplied by the dealer.<br />The question I have concerns the P/N 435009 Pulse Limiter - Threaded that I was given. It had a hex requiring a wrench of about 1" and it wouldn't clear the casting rib on the engine. The one it replaced had a hex of 7/16". About an hour with a file and I had removed enough of the hex to allow it clear the engine casting and was able to install it. Everything seems to be working OK.<br />Should I have used the old pulse limiter over?<br />Is there any problem with using the larger hex pulse limiter that was supplied? <br />The old limiter had what appeared to be a metal mesh in it while the new on appears to have some light colored material that almost looks like a filter.<br />The pump allowed the engine to start almost immediately, (on fuel/oil mix), and the oil pump also pumped oil right away. I used about 3 gal of premix to be sure the VRO was working, then hooked up the tank with just gas. No alarms other than when I was first checking the oil flow from the VRO.<br />Do I need to make any revisions to this installation?<br /><br />Charles
