fuel/oil ratio 1969 1.5 hp Johnson,
Joey One
Re: fuel/oil ratio 1969 1.5 hp Johnson,
25:1. You could go to 50:1 if smoke is a problem; but the more oil, the better with those old 2 strokes.
sharkman
Hey Joey thanks for the info.<br /><br />have a great day!<br /><br />Shark
JB
What marinemech said. 50:1.
seahorse5
All Johnson and Evinrude outboards since 1964 use a 50:1 fuel mix.
angus63
Just a little piece of wisdom from sitting around the shop when I was a kid in the late 60's. The old man who owned the joint must of been tired of the question about fuel/oil ratio for motors during that period and had a sign on the counter that read:<br />" If your motor was alive while JFK was alive, mix it 24:1. If your motor doesn't remember that terrible day, mix it 50:1."<br /><br />Kinda stuck with me and still can picture that sign today.
sharkman
Allright...thanks gang..fairly new to this site but am very impressed so far. awesome<br /><br />shark
WillyBWright
Use a fuel stabilizer all of the time. That little motor won't eat gas fast enough to keep it fresh unless you mix it a liter at a time.<br /><br />What is it in Canada, a Liter or a Litre? I'm used to Gallons and Ounces. Is 50:1 20ml/L? Oddly enough, if you mix it 16 oz per 6 gal tank like we do here, it's really 48:1...which is awfully close. :)
sharkman
hey Willy...according to my calculations (from the back of the oil can) the mixture in metric at 50:1 is 25 Litres of fuel to 500 millilitres of oil...........so it takes a bit of figuring out.<br /><br />(1 US gallon = 3.7854118 litres)<br /><br />(1000 millilitres = 1 litre)
Paul Moir
It's easier to work with the 20ml/l thing. Put 6 bucks worth of gas in, put 120ml in with it (6 x 20, or mentally 6 x 2 x 10). :D <br />Litre rather than liter since SI units are French in origin.<br />Buy the 'Premium Motomaster' 2-stroke oil at Canadian tire and it has a graduation on the side so you can measure out in ml.
