Re: Fuel/Oil Ratio Problem
Reducing the oil will most likely harm your engine.
In order of priority, the following items will help to reduce the carbon which if found on the spark plugs will also be found on all of the firing chamber, rings, pistons and exhaust:
1. Make sure that the thermostats are the correct ones for your motor, and that they function properly;
2. Use Synthetic blend or 100% synthetic oil;
3: Perform the recommended annual de-carbon treatment and use a carbon treatment additive in your fuel whenever you buy fresh fuel, and do the de-carbon treastment now;
4: Check with your local BRP dealer to be sure that you have the correct plugs and gap.
http://forums.iboats.com/showthread.php?t=158076
