Re: fuel/oil ratio testing
When in doubt, add the correct amount of oil. The engine will not be hurt with double oil.
I have a method that I use all the time: A tank does not get gas unless oil has been added--no exceptions. That way, when I go back a month later, I don't need to remember. If it has gas, it has the correct amount of oil.
All oils are tinted and will slightly tint the gas. With experience, the color will tell you if you 1. Have oil at all 2. Have enough, 3. Have too much.
Try it-- in a glass container add single strength and in another add double strength and hold them side by side.
