I will try to explain this in the written form. History first. 1977 22' Cuddy with Merc. 188 and 888 drive. Been in storage 8 years, brought it back to life a month ago with new oil, plugs, impeller, lower unit lube. Has started and run great for 4 weeks. The other night we were out on the lake in medium chop at 3/4 throttle heading back to our slip. All of the sudden she just seemed to go to idle. Didn't die. I sat in neutral for a few minutes and all seemed well with engine so I shifted in forward and off we went. 2 min. later same thing. oil pressure good, temp 140. Now getting nervous and darkness coming on, I slogged forward at low throttle. Went for a while then added a little juice to get back and she had ( now this is the hard part to describe) a vibration sound. Can't tell if it was sputtering bad or if sound came from drive. Basically, idled back to slip and parked it. Checked yesterday, checked oil and fired her up. All good, maybe a little over full on oil. With it tied up, shifted to reverse and it felt strong. Question: Can drive "slowly" go bad? Could this be fuel/water separator issue? It may have had some 10% fuel put in during start-up this month. Only have a short time left at slip and not much help for pulling out of water.
