Fuel Pickup Barb Material
I'm going to replace the fuel pickup tube on my gasoline tank and not sure if I should go with an aluminum or brass barb on it. The pickup connection is aluminum so I would think an aluminum barb would be better for corrosion. But... on the description of a Moeller anti-siphon hose barb it says this:
" Anti-siphon valves are required by Federal Law and the USCG on all permanent fuel tank installation. Use 15 (Brass) calibrated for HP 200 & above and 30 (aluminum) calibrated for HP below 200".
My engine is 200HP. Any suggestions?
Scott06
I would use brass it is no issue corrosion wise
Test your AS valve before spending beer money
