Fuel Polishing
bjcsc
Re: Fuel Polishing
Gasoline degradation is largely due to the loss of aromatic compounds through the vents. Diesel fuel, as you know, does not evaporate like gasoline. Specific algaes and other microbials can grow surprisingly well in diesel tanks as well, esp. when they have a decent supply of water either from condensation or lousy supply tanks. I run Biocide in my diesels, and pay attention to the fuel/water sep.. That is normally sufficient. Also, an average recreational diesel trawler may use a few tanks of fuel a season whereas as an average recreational gasoline boat may use a few tanks per month.
Mischief Managed
Re: Fuel Polishing
There's nothing to be gained by polishing gasoline. It does not generate asphaltine, can absorb quite a bit of water without damaging the engine, and gas engines do not require extremely fine filtering. Fuel polishing equipment is absurdly expensive too.
