Re: Fuel pouring from carb's
You you suggested "pouring out," and I think float stuck. Carbs will seep fuel...especially after being tilted up...but this is different than pouring out. Before you do anything...how does the motor run?? A motor will not run well with a stuck float...let alone two.
Being that you said the "bottom two," it's kinda unlikely that two carb floats at the exact same time are causing the problem...again, how does the motor run?
MAS
