I talked to you last week on getting fuel pressure for a 70h.p. Evinrude V.R.O. I'm getting about 5 p.s.i. At times the gage will fluctuate slightly going down a lb. or two. Does this indicate a possible air leak in line?This is not the normal fluctuation when the pump is injecting oil.The pump clicks and drops in pressure just for a second when this happens.This is less of a fluctuation and it has no pattern.
