sknywhtdude
- Joined
- Oct 3, 2010
- 12
Had the boat on the water it was running fine at full throttle then after about 30 minutes it didn't have enough power to get on plane. I replaced the primer bulb, fuel lines, spark plugs, and fuel filter. It starts then won't even stay running for over a minute. It cranks up fine. I give it gas and sounds like its starving for fuel. What else could be the cause of this problem? I have fishing to do!
A few times at idle it will pop and a puff of white smoke comes out...don't remember it doing that before. I don't want to take it into a mechanic if its just a simple fix i can do here at home. Also how much oil should it be getting? Its oil injected could it be possible its getting to much oil? When i look at the carbs it has a little oil drippin when i pull off the air vent. And my old spark plugs were really black and with fuel and oil on them? Spark issue maybe electrical somewhere? I'm not an expert.
